we are running an icinga2 cluster with >1.5k hosts monitored. I was tracing down a different issue with our dns when I found out that icinga2 resolves the PTR record to every IP address it gets. This ends in thousands of SERVFAILS per minute.
When there is a hostname in “address” it resolves A first, then AAAA and then PTR to the A record. When there is an IP it only resolved PTR.
Is this a feature or a bug?
# icinga2 --version
icinga2 - The Icinga 2 network monitoring daemon (version: r2.11.3-1)
Copyright (c) 2012-2021 Icinga GmbH (https://icinga.com/)
System information:
Platform: Debian GNU/Linux
Platform version: 9 (stretch)
Kernel: Linux
Kernel version: 4.9.0-12-amd64
Architecture: x86_64
Build information:
Compiler: GNU 6.3.0
Build host: runner-LTrJQZ9N-project-298-concurrent-0
Application information:
General paths:
Run directory: /run/icinga2
Old paths (deprecated):
Installation root: /usr
Sysconf directory: /etc
Run directory (base): /run
Local state directory: /var
Internal paths:
# icinga2 feature list
**Disabled features:** compatlog debuglog elasticsearch gelf graphite icingastatus influxdb livestatus opentsdb perfdata statusdata
**Enabled features:** api checker command ido-mysql mainlog notification syslog
