Is it possible to manually execute and get the output of the built-in check commands? For example, I would like to, for testing purposes, execute the icinga, cluster, icingadb and ido embedded checks.
For external checks, such as check_nrpe, I am able to manually run the executable. But for these embedded checks, I’m not sure if it’s possible since they seem to be embedded within Icinga2.
