Making and integrating graphs into icinga with rrdtool
rrdtool module setup Almalinux 9
Download module from icingaweb2-module-rrdtool v1.5.1.zip
Unzip and move to
/usr/share/icingaweb2/modules/rrdtool
Set same permissions as other modules and fix ownership.
Also
restorecon -RFv /usr/share/icingaweb2/modules/rrdtool
Install dependencies for almalinux 8 or 9.
dnf install -y rrdtool perl-rrdtool perl-Time-HiRes php-gd php-xml php-pecl-rrd
perl-Time-HiRes php-gd php-xml are most likely already installed if your icinga is working.
create datadir and fix ownership. Also restorecon
/var/lib/icingaweb2/rrdtool/
chown root:icingaweb2 /var/lib/icingaweb2/rrdtool/
restorecon -RFv /var/lib/icingaweb2/rrdtool/
enable perfdata incase not enabled. Restart is required if wasn’t previously enabled.
icinga2 feature enable perfdata
systemctl restart icinga2.service
Enable module via UI. And set the following settings.
Path to RRD and XML files:/var/lib/icingaweb2/rrdtool/
Path is readable: Should be a green check mark here.
Path to templates:/usr/share/icingaweb2/modules/rrdtool/templates/
Path to PerfdataWriter output:/var/spool/icinga2/perfdata
Checks with multiple RRDs: Leave empty
Enable perfdata processing: Set this on
Enable logging: Set this on if you want logs
Verbose logging: Set this on if you want verbose logs
PHP RRD Extension: Should be a green check mark here.
Path to rrdtool binary: rrdtool
Override max thumbnails: Leave this empty.
SAVE CHANGES!
Now running :
icingacli rrdtool process
Should result in some rrd and xml files under your datadir
ls -larth /var/lib/icingaweb2/rrdtool/your_host/
Check log for possible errors:
/var/lib/icingaweb2/rrdtool/rrdtool.log
Services that have been in unknown state will not produce data. Logs will tell you if this is the case.
Set a cron job so that rrd are regurlary updated.
#cat /etc/cron.d/process_rrd
#process data
*/5 * * * * root /usr/bin/icingacli rrdtool process
Creating graphs for ssh response time last hour:
rrdtool graph ssh_graph_1.png --start now-3600s --end now DEF:1=/var/lib/icingaweb2/rrdtool/your_host/ssh.rrd:1:AVERAGE LINE1:1#FF0000:“SSH response time”
This is where i put my SELinux back on to see if it would break the installation. It did this is because php-fpm is not able to read the data directory. Easy fix is to make a module which allows it to read it. Or you can also fix the context to httpd_t for the directory (recommended).
Or to be a noob and not use SELinux alltogether.(But what would Dan Walsh think of you then? https://stopdisablingselinux.com/)
Now this is as far as I managed to do by myself in a short time period.
If i do this part which is mentioned in the “installation” guide.
When you use checkcommands like nrpe, that actually call other commands, you can add a customvar like rrdtool to your services and append it to the checkcommand in your perfdata to allow differentiation:
object PerfdataWriter “perfdata” {
rotation_interval = 10s
service_format_template = “DATATYPE::SERVICEPERFDATA\tTIMET::$service.last_check$\tHOSTNAME::$host.name$\tSERVICEDESC::$service.name$\tSERVICEPERFDATA::$service.perfdata$\tSERVICECHECKCOMMAND::$service.check_command$$rrdtool$\tHOSTSTATE::$host.state$\tHOSTSTATETYPE::$host.state_type$\tSERVICESTATE::$service.state$\tSERVICESTATETYPE::$service.state_type$”
Results as missing macro in logs:
[2023-10-11 15:44:12 +0300] warning/MacroProcessor: Macro ‘rrdtool’ is not defined.
Context:
(0) Resolving macros for string ‘DATATYPE::SERVICEPERFDATA TIMET::$service.last_check$ HOSTNAME::$host.name$ SERVICEDESC::$service.name$ SERVICEPERFDATA::$service.perfdata$ SERVICECHECKCOMMAND::$service.check_command$$rrdtool$ HOSTSTATE::$host.state$ HOSTSTATETYPE::$host.state_type$ SERVICESTATE::$service.state$ SERVICESTATETYPE::$service.state_type$’
(1) Writing performance data for object ‘icinga!ssh’
If I add a variable
vars.rrdtool = “rrdtool”
to the template Service “generic-service” it goes away since now we have it defined.
But I really don’t know how to visualize and integrate the rrd files into icinga as the projects images suggest that they’re able to do. I’m obviously lacking some configuration on icinga. What should be done in order to have the same visualization as in the module front page suggests? rrdtool :: Icinga Exchange
TBH the documentation is lacking for this project. I think each module project should have clear information on how to actually install it and achieve the status which the images on the project show.
Not everyone has the time/knowledge to do this. Projects like this should be more accessible.
Much help would be appreciated.
Also shoutout to https://freedom-for-icinga.com/ for offering a RHEL 9 repo for free.
