alright, after installing it, are there specifics configurations to do or it’s ok when i install it ?
bsd-mailx does not need any configuration. In general, I’d recommend to test mail manually by calling it directly via CLI.
Thank you very mutch now when i send forced notificatons from my web interface i get them, But when a service comes to critical state i don’t get the mail, i sent my confs higher in the topic maybe there is a mistake or something missing ? tell me if you want to see more of my confs file .
Did you fix this already?
Unfortunately, you don’t format your messages properly (as described here), hence it’s hard to read and impossible to cut and paste from your images. Therefore, I have no clear overview of your config. But, one thing looks strange: You have import at your apply Notification which most properly should by command instead.
Sorry i think the server needed some time but now it works thank you
