I am looking for the source for icingadb-redis. I am on Rocky Linux 8 and package support for this distribution is limited.
I can find the github source for icinga2, icingadb and icingaweb2 under
but I don’t find anything for icingadb-redis.
here you go:
the source rpms contain the sources and a spec file that might need some rocky linux specific changes
or maybe that helps:
Thanks. The link to packages.icinga.com helps.
I looked on GitLab but only find spec files for icinga2, icingadb and icingaweb2.
the spec files are also in the src rpms
Yes, I found the spec files and was able to use them with modifications.
