I have encounter a little issue when i configuring a filter from Oracle logs monitoring. My idea is to add more oracle errors in the same filter like this:
# cat filter-60-ORA-609.conf
filter {
if [message] =~ /ORA-1653/ {
grok {
match => ["message","(?<oracle-error-message>ORA-[0-9]*)"]
id => "oracle-error-message"
add_tag => "oracle-error-message"
tag_on_failure => ["_grokparsefailure","oracle-error-message_failed"]
filter {
if [message] =~ /ORA-1654/ {
grok {
When I generate some logs which contains error codes like the two mentioned, i can see both events in Kibana, but in Icinga2 output only first generate an alarm (ORA-1653) .
Can someone suggest me how can i add more specifics ORA-XXXX errors in the same file and make the icinga2 output to work for every event, not only for first ?
This depends heavily on how you proceed with the parsing of the logs. I don’t see any configuration on how you forward the data to Icinga.
By the way, you could make your filter a bit more universal.
filter {
if [message] =~ /ORA-/ {
grok {
if [oracle-error-message] in ["ORA-1653","ORA-1654"] {
# do something to forward it into icinga
That way you can add more and more errorcodes to your if clause and all errorcodes are treated the same. Please note that I hacked this code into discourse right now and did not test if it’s not full of typos.
I succed to forward multiple logs messages with different errors messages in the following way :
[root@cormoran oracle]# cat filter-60-ORA-XXXX.conf
filter {
grok {
match => [“message”,"(?ORA-[0-9])"]
id => “ORA-1653”
add_tag => “oracle-error-message”
tag_on_failure => ["_grokparsefailure",“oracle-error-message_failed”]
filter {
grok {
id => “ORA-1654”
Now i have another problem, i can’t raise the alarm in icinga for different hosts depends of the tag “fields.name” from kibana .
I’m sorry, that really depends on the rest of your Logstash and Icinga configuration. icinga_host has to be set to the exact value like the name of the host object in Icinga 2 you want to send the check result for. “exact” meaning including shortname vs. fqdn, capitalization etc.
