Linuxfabrik memory-usage max 2 Gb
After some awesome help in this forum I got the Linuxfabriks monitoring plugins to work and have setup CPU and Memory checks for Linux servers. It all looks like it’s working and I get performance data/graphs OK, but then I took a closer look, and the memory-usage seems to cap at 2Gb? The below host data shows total memory 2 Gb:
But if I run the memory-usage locally on the host it returns 3.8 Gb (which is correct):
What am I doing wrong?
I think it’s actually shows the data from the Icinga server??
This is the data from that:
Is the problem maybe that it doesn’t run on the agent?
OMG:… I was probably really tired this morning, had forgot to have the service template set to “Run on agent”… DOH!! :upside_down_face:
