Link to object in Director
I’m probably missing something small and obvious here, but I can’t find a way to get back the “Actions/Modify” button (or similar) after I migrated to Icinga DB Web. I noticed the Inspect action moved to a tab called Source, but can’t find a link to the Icinga Director object anywhere in the details view.
Is it not supported anymore? Or what have I missed?
  • Icinga DB Web version: 1.0.1
  • Icinga Web 2 version: 2.11.1 (eecf8d9934cbf30ec063cea4a525b26bfd2bf99a)
  • Web browser: Chrome
  • Icinga 2 version: r2.13.5-1
  • Icinga DB version: 1.0.0
  • PHP version used: 7.3.33
  • Server operating system and version: CentOS 7.8
which version of director do you use? my inspect and modify links are there (director 1.9.1)
Hi, please have a look here: Modify link to Icinga Director is missing · Issue #644 · Icinga/icingadb-web · GitHub
Hi, thanks for replying. That would’ve been good information for me to add in the post :smiley:
I run Director 1.9.1 as well. Incubator 0.17.0. I just upgraded the whole environment when upgrading to IcingaDB.
Yep! This solved the issue! Thank you so much!
ahh, it’s there because I use the monitoring and icingadb-web module simultaneously and gone after disabling the monitoringmodule
