I want to get to know more about the Icinga2 DSL, where is a good place to start for…
- What is is good for?
- Tutorials, learning resources.
Thank you, and keep safe
Hi There,
For your first question, I am probably not the right person
For your second question you can find the icinga documentation here (perhaps you already seen this):
Also a new cool feature:
Getting to know the DSL in this case is mostly using it, looking at forums, getting a problem in a test setup. and just having fun destroying your prod env
Its the way I learned for as much as I did.
Hi for your question 1 could look into this: Checking service clusters in Icinga 2 @mfrosch wrote a complete check with the Icinga DSL
