Lab/Production Monitoring Design
What would be a good design to monitor 2 separate “sites”?
I would not like to see warnings of the lab at the same place where I see production warnings.
I could just clone all the setup and just have different hosts in the icinga DB but that will require for me to maintain both for when I want to upgrade or add plugins etc.
Is there a way to have a different view per user or something else?
Hello and welcome,
i usualy add a variable to every host and/or service object that i can use in the icingaweb roles to allow the users with this role to see these objects only they should see.
See the icingaweb dokuhttps://icinga.com/docs/icingaweb2/latest/doc/06-Security/#restrictions and if you still have question, just ask here.
Regards,
Carsten
