- Version used (r2.14.0-1)
- CentOS Linux 7
- Icinga Web 2 version - 2.12.1
- Disabled features: compatlog debuglog elasticsearch gelf graphite icingadb influxdb2 journald livestatus opentsdb perfdata syslog
Enabled features: api checker command ido-mysql influxdb mainlog notification
Hi, kat,
Icinga doesn’t quite work that way. You setup your monitoring and customize it according to your needs.
Quick search provided this information: Install 3rd party software (Nagios Agent) On ExaCS ( OCI )
I don’t have an oracle account, but you might.
