Kate Syntax Highlighting for Icinga2 Config Files
I couldn’t find an Icinga2 config file language sensitive editor for Kate, so I’ve put one together (attached). You just need to unzip the XML file from the attachment, and put it into the relevant directory - see https://docs.kde.org/stable5/en/kate/katepart/highlight.html:
Custom .xml highlight definition files are located in org.kde.syntax-highlighting/syntax/ in your user folder found with qtpaths --paths GenericDataLocation which usually are $HOME/.local/share/ and /usr/share/ .
HTH someone else.
icinga2.zip (3.0 KB)
Solved - the file is attached to the original post.
