Hello friends,
Is there any possible to Juniper switch monitoring FAN, TEMP, POWER SUPPLY and switch Stack. Pls share me any plugin for this.
Hello friends,
I can’t say whether these switches support monitoring those specific values,
but https://www.juniper.net/documentation/us/en/software/junos/network-
mgmt/topics/topic-map/network-monitoring-by-using-snmp.html should point you
in the right direction.
Note that SNMP is not enabled by default on Juniper equipment.
Antony.
Hi Antony,
Thanks for your golden time. Already we’re monitoring juniper switch CPU,RAM via SNMP v2. But I need TEMP, FAN status, POWER SUPPLY and Switch stack. Do you have any idea for this.
I use two different approaches, to handle checks via SNMP:
Sorry; no. It wasn’t clear to me from your original question that you were
already monitoring anything at all on these devices using SNMP, so I thought
that was the clue you were looking for.
In terms of the specific parameters you’re now trying to measure, I think this
is more of a question for Juniper than the Icinga list. There might be
someone here who is doing what you want, but Juniper support would definitely
know, I think.
Antony.
