JBOSS Monitoring with Icinga
Hi all, I have a JBOSS application server installed, I didnot know how to do monitoring of that specific one. Just want to ask here that is there a plugin created to monitor JBOSS or something which can give me a start. It will be much appreciated and will help me alot if there is something related to this occurs
You could try https://exchange.nagios.org/directory/Plugins/Java-Applications-
and-Servers/JBOSS
Disclaimer: I have no clue about JBoss; I simply did a web search using
Google.
Antony.
Maybe this helps:
https://icinga.com/docs/icinga-2/latest/doc/10-icinga-template-library/#jmx4perl
Install check_jmx4perl and enable/install the Jolokia API on your JBOSS. It works well with any type of Java, like Wildfly, JBOSS, Tomcat etc
https://labs.consol.de/jmx4perl/index.html
https://labs.consol.de/jolokia/index.html
