Issues with icingacli businessprocess process check
I have created two separated businessprocess as follows:
SERVER_ROOM_TEMPRATURE OR
GEFEN_INTERNET_STAT OR
I created service check for each of them in the beginning GEFEN_INTERNET_STAT is working well
But as i added second service check i get following error showed below
 Plugin Output
Checking Business Process 'GEFEN_INTERNET_STAT' failed: The node "SERVER_ROOM_TEMPRATURE" doesn't exist
I cant understand how they are related , maybe i missed something?
Please advice
temprature internaetstat
Hi and welcome,
can you supply the command line of your BPM check and also if possible the configuration file of the BP (I dont use the UI to create them).
Regards,
Carsten
thanks
i managed i found out i missed field (shown below) , and now its works
icingacli_businessprocess_config
Hi, I have the same problem.
Could you show how you solved the problem with that field in Director?
Best Regards / Jens
Hi ,
Yes sure
Thank you :slight_smile:
Hello there and welcome to the community!
Could you mark your answer with the screenshot as the solution please?
I was a little confused when reading through this topic at first :slight_smile:
Thank you!
Feu
