Hi guys. I having some problems to configure the disk graphs repeating in the Icinga2 grafana module. The issue is that only one graphs is showed, and I think I have detected the “bug”.
In the file: /usr/share/icingaweb2/modules/grafana/library/Grafana/ProvidedHook/Grapher.php
I found this piece of code:
if ($this->repeatable == "yes") {
$this->panelId = implode(',', range($this->panelId,
($this->panelId - 1) + intval(substr_count($object->perfdata, '=') / $this->numberMetrics)));
Well, the problem is that $object->perfdata is supposed to return the perfdata output, to know the number of disks checked by this service, and this way it can calculate the number of graphs to show. But $object->perfdata is returning “1” (I think that it means “Perfdata enabled”) but not the perfdata output string as expected.
And here is my question: is there any way to get the perfdata output string? I have readed the doc and I can’t find a way to do it. Thanks in advance.
Icinga Web 2 version 2.11.4
Loaded Modules
director 1.10.2
fileshipper 1.2.0
grafana 1.4.3
icingadb 1.0.2
incubator 0.20.0 -
Web browser used (Chrome, Firefox and Edge)
Icinga 2 version used r2.13.6-1
PHP version used 7.4.33
Server operating system and version Debian 11 bullseye
