Cheeres All,
i got a Problem with assign Host Notification:
If i assign the host notification to any Group, for example i deploy a new host from director, the host is not showing on icingaweb2.
If i disable or remove the assign in host notification, the new host shows up…
Same issue with delete Hosts. If i delete one with active host notification, the host still on icingaweb2 but is allready deleted on director…
What do i wrong?
my apply conf.
i tried allready to setup a variable
but i cant deploy it
sorry for my bad english btw.
Used version:
Director → 1.8.1
Icingaweb2 → 2.8.2
If i disable the notify i can deploy and remove host but i guess this ist not solution either
