After upgrade to icingaweb2.9.5 from 2.7.5 i am seeing this :
Fatal error: Uncaught exception 'ErrorException' with message 'Invalid argument supplied for foreach()' in /usr/share/php/Icinga/File/Ini/IniParser.php:271
Stack trace:
#0 /usr/share/php/Icinga/File/Ini/IniParser.php(271): Icinga\Application\ApplicationBootstrap->Icinga\Application\{closure}(2, 'Invalid argumen...', '/usr/share/php/...', 271, Array)
#1 /usr/share/php/Icinga/Application/Config.php(326): Icinga\File\Ini\IniParser::parseIniFile('/etc/icingaweb2...')
#2 /usr/share/php/Icinga/Application/Config.php(397): Icinga\Application\Config::fromIni('/etc/icingaweb2...')
#3 /usr/share/php/Icinga/Application/ApplicationBootstrap.php(589): Icinga\Application\Config::app()
#4 /usr/share/php/Icinga/Application/Web.php(89): Icinga\Application\ApplicationBootstrap->loadConfig()
#5 /usr/share/php/Icinga/Application/ApplicationBootstrap.php(416): Icinga\Application\Web->bootstrap()
#6 /usr/share/php/Icinga/Application/webrouter.php(107): Icinga\Application\ApplicationBootstrap::start()
#7 /usr/share/icingaweb2/public/index.php(4 in /usr/share/php/Icinga/File/Ini/IniParser.php on line 271
is there any way to make those error messages show actual file names, instead of truncated ones?
