Is there any way to check or monitor log files or text using icinga
Hi all i want to know is there any methods to check or monitor log files or text , if so Will it check information on a log file to see if there are any errors or issues
Here are a couple of the results I got from a Google search for “icinga log
file check”.
https://exchange.icinga.com/lausser/check_logfiles
https://exchange.nagios.org/directory/Plugins/Log-Files
Hope that helps,
Antony.
