I’m explicitly trying to understand why I might get something like:
Error: Error while evaluating expression: Operator + cannot be applied to values of type ‘String’ and ‘Dictionary’
Location: in /usr/local/etc/icinga2/conf.d/services.conf: 61:3-61:16
/usr/local/etc/icinga2/conf.d/services.conf(59): check_command = “http”
/usr/local/etc/icinga2/conf.d/services.conf(60): zone = “master”
/usr/local/etc/icinga2/conf.d/services.conf(61): vars += config
When I have something like:
apply => 'http_check => config in host.vars.custom_checks',
and then some hiera like:
test-lb:
vars:
custom_checks:
https:
http_address: "%{lookup('icinga2::custom_hosts.test-lb.address')}"
http_vhost: "%{lookup('icinga2::custom_hosts.test-lb.address')}"
http_uri: '/wp_login/'
http_sni: 'true'
http_ssl: 'true'
http_ssl_force_tlsv1_or_higher: 'true'
http_verbose: 'true'
http:
cert_check:
http_sni: 'true'
http_ssl: 'true'
http_certificate: '28' # Number of days that a cert must be valid for
This works, but incorrectly, it only applies the very final values (the ones for the cert_check). However, if I change apply to like follows for example:
apply => 'http_check => config in host.vars.custom_checks.http',
Then I will get the error message quoted at the beginning of this message complaining about merging a string and a dictionary object. So what I need to understand is this weird syntax for apply.
I’m going to try to break it down. config in host.vars.custom_checks will loop over each key? So is will be:
[{'https': {'http_address': '...', etc.}}, {'http': {}}, {'cert_check': {}}]
But then I don’t understand the http_check => bit, it looks a little like JS/Ruby syntax, JS for an arrow function and Ruby whatever the hash rocket thing is.
Some time later …
Okay, and here it is. I needed to add a stub inbetween so that I could do this.
My apply line as I tried out earlier:
But this time I’ve had to add a key called vars so that the http_check can iterate over the http, like this:
test-lb:
vars:
custom_checks:
https:
vars:
http_sni: 'true'
http_ssl: 'true'
http:
vars:
cert_check:
vars:
http_sni: 'true'
http_ssl: 'true'
This is definitely something that needs documenting and explaining pretty much everywhere so that it’s understandable.
