I want create the next notifications using icingacli director.
Someone can help please.
Regards.
Regards.
Hi
try
icingacli help director notification <action>
whithout any action the command shows you a little help what is possible
Hi Stevy,
Thansk for you response. I can create the notificactions with the next command.
icingacli director notification create “notification sbc host” --json ‘{ “object_type”:“apply”, “imports”: “template notications”, “users”: “cliente1”, “apply_to”: “host”, “assign_filter”: “host.enable_notifications!=%22false%22”}’
