Is a common master VIP a problem
I have a quick question about having a common vip for masters.
Is this a problem from the satellite point of view to have both masters sharing the same ip and dns name for their endpoint ?
I’m almost sure not.
a small question about this:
How you want to configure this? If your solution will be keepalived and every node has it’s own address it’s no problem.
We using this solution this for the api and icingaweb. In case master 1 is down keepalive is routing the requests for the api and icingaweb to the master 2. Works fine
ok thanks, i got the problem now, in the configuration i was preparing, not every node have it’s own address, it was actually the vip which stands for multiple nodes at once which would lead me to config issues.
