I am facing some problems in order to configure a new nrpe check in Icinga Director. This is the original command executed on the command line:
root@mon01:/usr/lib/nagios/plugins# ./check_nrpe --host 193.170.144.111 -c check_load
OK - load average: 0.13, 0.09, 0.02|load1=0.130;15.000;30.000;0; load5=0.090;10.000;25.000;0; load15=0.020;5.000;20.000;0;
For some reason the check does not get the IP address when I configure it in Director. I am proceeding as usual: I made the command configuration, the service check and finally the service apply rule. Please find enclosed some screenshots:
As you can see on the inspect screenshot, instead showing up the ip address I had configured it shows just this "‘Object of type ‘’‘Host’’’’.
Thank you in advance for your help.
Regards,
Javier
