Invoke-IcingaCheckUsedPartitionSpace with JEA aktiv
Hi everyone,
I’m having an issue on a server with Invoke-IcingaCheckUsedPartitionSpace
When I run the command directly on the server, I get the correct data for all drives:
[INFO] Partition C: 58.81GiB _
[INFO] Partition E: 682.09GiB _
[INFO] Partition F: 374.60GiB
However, on my Icinga server, an error is displayed. Specifically, drive E: cannot be read:
Free Partition Space: 3 Ok
_ Partition C: 58.81GiB (62.13%)
_ Partition E: 0B (0%)
Partition F: 374.60GiB (24.39%)
For your information, I have JEA enabled for Icinga. All other checks are working fine.
Where would you recommend I start troubleshooting this?
Thank you very much
regards
Stefan
  • versions of icinga powershell framework
  • versions of icinga powershell plugins
  • permissions on drive E?
    • I think the jea profile only takes care of powershell permissions not partition access
    • Is E super restricted, has the icinga user access to E?
and there is this magic icinga powershell command:
Test-IcingaForWindows -ResolveProblems
that fixed a lot of problems
Was anything of my post helpfull?
Hello Moreamazingnick,
I restarted the Icinga services with a local admin account again. Everything works. The proposed solutions are too difficult and time-consuming for me. Still, thank you very much for your help.
Kind regards
Stefan
