Hello everyone
with the Invoke-IcingaCheckCPU we sometimes have these spikes to over 100%.
How does this happen? Is this a bug?
Does this have anything to do with this topic?
But 2000?
Many thanks
Hello everyone
But 2000?
Many thanks
yes that was a bug and is fixed with v1.13.0. Values can go higher than 100%, but it should be on the percentage maximum of the base and boost clock of. the CPU.
If your base clock is 3GHz and the boost block is 4GHz, the maximum in % CPU load you see should be around 125%.
