I want to implement the check “Invoke-IcingaCheckCertificate”. In powershell this is the following call
Invoke-IcingaCheckCertificate -CertStore ‘LocalMachine’ -CertStorePath ‘My’ -CertSubject ‘*’ -Trusted -WarningEnd ‘30d:’ -CriticalEnd ‘10d:’
In the past I always have the required fields defined and could then use them in the Icinga director as custom fields. However, some required fields say " /* Unable to fetch function body through API */". While searching I came across some articles which I didn’t understand.
Is it possible to configure the check in the director with the parameter certstore?
Moreamazingnick:
1.10.2
Ok thanks I have the director 1.9.1. I try it with the newer version.
log1c
April 20, 2023, 6:15am
4
The newer version will only change the message, but the “function body” will still not be visible inside the Director.
See here: Feature Request / Readability Improvement · Issue #2557 · Icinga/icingaweb2-module-director · GitHub
You can still use everything that you have defined there, like variables and so on. It’s just a displaying issue.
If you import the basket into the Director like @moreamazingnick said, the whole DSL code willbe visible.
This issue only applies when importing commands into the Director that where configured in the configuration files.
