Hello Icinga-Community,
after upgrading our icinga environment from Icinga IDO to Icinga DB we have an unusual error when executing some steps within Icinga Web. The error doesn´t appear after every button or task, only in some scenarios. I also updated all modules and other icinga related software on the system.
First example:
- Go to director and search for a host and go to it
- Click on “delete”
- Error appears: Invalid CSRF token provided
The strange thing is, that deleting a other host worked.
Second example:
- Go to Icinga Director Activity Log
- Click Deploy pending changes
Third example:
- Go to Overview and search for a specific host
- Set downtime and fill in the needed information
- Error:
#0 [internal function]: Icinga\Module\Icingadb\Forms\Command\CommandForm->ipl\Web\Common{closure}() #1 /usr/share/icinga-php/ipl/vendor/ipl/validator/src/CallbackValidator.php(43): call_user_func() #2 /usr/share/icinga-php/ipl/vendor/ipl/validator/src/ValidatorChain.php(269): ipl\Validator\CallbackValidator->isValid() #3 /usr/share/icinga-php/ipl/vendor/ipl/html/src/FormElement/BaseFormElement.php(273): ipl\Validator\ValidatorChain->isValid() #4 /usr/share/icinga-php/ipl/vendor/ipl/html/src/Form.php(322): ipl\Html\FormElement\BaseFormElement->validate() #5 /usr/share/icinga-php/ipl/vendor/ipl/html/src/Form.php(303): ipl\Html\Form->validate() #6 /usr/share/icinga-php/ipl/vendor/ipl/html/src/Form.php(235): ipl\Html\Form->isValid() #7 /usr/share/icingaweb2/modules/icingadb/library/Icingadb/Common/CommandActions.php(195): ipl\Html\Form->handleRequest() #8 /usr/share/icingaweb2/modules/icingadb/library/Icingadb/Common/CommandActions.php(162): Icinga\Module\Icingadb\Controllers\HostController->handleWebRequest() #9 /usr/share/icingaweb2/modules/icingadb/library/Icingadb/Common/CommandActions.php(283): Icinga\Module\Icingadb\Controllers\HostController->handleCommandForm() #10 /usr/share/icingaweb2/modules/icingadb/library/Icingadb/Web/Controller.php(468): Icinga\Module\Icingadb\Controllers\HostController->scheduleDowntimeAction() #11 /usr/share/php/Icinga/Web/Controller/Dispatcher.php(76): Icinga\Module\Icingadb\Web\Controller->dispatch() #12 /usr/share/icinga-php/vendor/vendor/shardj/zf1-future/library/Zend/Controller/Front.php(954): Icinga\Web\Controller\Dispatcher->dispatch() #13 /usr/share/php/Icinga/Application/Web.php(294): Zend_Controller_Front->dispatch() #14 /usr/share/php/Icinga/Application/webrouter.php(105): Icinga\Application\Web->dispatch() #15 /usr/share/icingaweb2/public/index.php(4): require_once(String) #16 {main}
Also in this case is really weird, that other hosts can be deleted as normal or if we search with the global search bar not within the Overview tab for the same host sometimes it works. So sometimes it works with special steps and sometimes not.
- Icinga Web 2 version
- 2.12.2
- Used modules and their versions (System - About)
|businessprocess||2.5.1||
|director||1.11.2||
|fileshipper||1.2.0||
|generictts||2.1.0||
|grafana||2.0.3||
|icingadb||1.1.3||
|idoreports||0.10.1||
|incubator||0.22.0||
|pdfexport||0.11.0||
|reporting||1.0.2||
|setup||2.12.2||
|toplevelview||0.4.0||
- Web browser used
Google Chrome - Icinga 2 version used (
icinga2 --version)
r2.14.3-1 - PHP version used (
php --version)
PHP 8.3.14 - Server operating system and version
- Red Hat Enterprise Linux release 8.10
