icinga2 version: r2.13.7-1
Debian 11
mariadb Ver 15.1 Distrib 10.5.18-MariaDB, for debian-linux-gnu (x86_64) using EditLine wrapper
FWIW I’m attempting this installation in a Proxmox container.
Following installation instructions; Debian - Icinga DB
systemctl status icinga2; running
When I systemctl start icingadb
Why;
(using password: NO)in the systemctl status message? I have a password set in/etc/icingadb/config.yml -
Seems suspicious;
localhost:0I would thinklocalhost
systemctl status icingadb
* icingadb.service - Icinga DB
Loaded: loaded (/lib/systemd/system/icingadb.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Wed 2023-03-15 14:32:13 MST; 33min ago
Process: 12388 ExecStart=/usr/sbin/icingadb --config /etc/icingadb/config.yml (code=exited, status=1/FAILURE)
Main PID: 12388 (code=exited, status=1/FAILURE)
CPU: 7ms
Mar 15 14:32:13 icinga0 systemd[1]: Starting Icinga DB...
Mar 15 14:32:13 icinga0 icingadb[12388]: Starting Icinga DB
Mar 15 14:32:13 icinga0 systemd[1]: Started Icinga DB.
Mar 15 14:32:13 icinga0 icingadb[12388]: Connecting to database at 'localhost:0'
Mar 15 14:32:13 icinga0 icingadb[12388]: database: Can't connect to database. Retrying
Mar 15 14:32:13 icinga0 icingadb[12388]: Error 1045: Access denied for user 'icingadb'@'localhost' (using password: NO)
can't retry
github.com/icinga/icingadb/pkg/retry.WithBackoff
github.com/icinga/icingadb/pkg/retry/retry.go:64
github.com/icinga/icingadb/pkg/driver.RetryConnector.Connect
github.com/icinga/icingadb/pkg/driver/driver.go:32
database/sql.(*DB).conn
database/sql/sql.go:1393
database/sql.(*DB).PingContext
database/sql/sql.go:851
database/sql/sql.go:873
main.run
github.com/icinga/icingadb/cmd/icingadb/main.go:68
main.main
github.com/icinga/icingadb/cmd/icingadb/main.go:37
runtime.main
runtime/proc.go:250
runtime.goexit
runtime/asm_amd64.s:1594
can't connect to database
main.run
main.main
runtime.main
runtime/proc.go:250
runtime.goexit
main.run
github.com/icinga/icingadb/cmd/icingadb/main.go:70
main.main
runtime.main
runtime/proc.go:250
runtime.goexit
Mar 15 14:32:13 icinga0 systemd[1]: icingadb.service: Main process exited, code=exited, status=1/FAILURE
Mar 15 14:32:13 icinga0 systemd[1]: icingadb.service: Failed with result 'exit-code'.
root@icinga0:~#
