Install icinga2 client on centos7
Hello
i try to find some Information about installing ONLY the Icinga Client on a centOS7.
The Master is runnig fine under Debian.
Thanks your help
vinc
you need to install the icinga2 package and the required check plugins that should be executed. The client setup will only active the features which are required on a client.
More information and detailed instructions on how to setup a client ca be found in the documentation.
https://icinga.com/docs/icinga2/latest/doc/06-distributed-monitoring/#clientsatellite-setup
Kind regards
Thank you @mcktr
Thanks for your feedback
the question goes more on a Debian Client i have to do also this
wget -O - https://packages.icinga.com/icinga.key | apt-key add -
vi /etc/apt/sources.list
deb http://packages.icinga.com/debian icinga-stretch main
deb-src http://packages.icinga.com/debian icinga-stretch main
Then just to Install this
apt install -y -f icinga2
apt install -y -f nagios-plugins
so what to add to the Source.list at first?
further i will just change apt with yum :wink:
have a nice day
vinc
check the docs for available repos here:
https://icinga.com/docs/icinga2/latest/doc/02-getting-started/#setting-up-icinga-2
For CentOS: https://packages.icinga.com/epel/
Greetz
@fluxX
Thanks a lot
it works it is addes just missing the check_yum on the master check_yum is not there because i think it is a debian9 running
have a nice day
vinc
