Hi All!
We started using the Influxdb2Writer function in Icinga2 v2.13 and found that due to a parsing error, influxdbWriter cannot process dynamic service names. The icinga2.log shows the following entries only:
[2022-01-10 13:45:30 +0100] warning/Influxdb2Writer: Unexpected Content-Type: application/json; charset=utf-8
[2022-01-10 13:45:30 +0100] warning/Influxdb2Writer: Unexpected response code: Bad Request
Analyzing with Wireshark, we found that in case of dynamic service, parsing errors occure. I.e. in case of inner service name ‘[DMZ] Apache vhost: { host = “my-vhost-name.local” }’ the Wireshark shows this:
check_http,hostname=my-host.local,service=[DMZ]\ Apache\ vhost:\ {
host\ \=\ \"my-vhost-name.local\"
},metric=time unit="seconds",value=0.137194 1642064342
},metric=size unit="bytes",value=19807 1642064342
X-Platform-Error-Code: invalid
Date: Thu, 13 Jan 2022 08:57:05 GMT
Content-Length: 419
{"code":"invalid","message":"unable to parse 'check_http,hostname=my-host.local,service=[DMZ]\\ Apache\\ vhost:\\ {': missing fields\nunable to parse 'host\\ \\=\\ \\\"my-vhost-name.local\\\"': missing fields\nunable to parse 'check_http,hostname=my-host.local,service=[DMZ]\\ Apache\\ vhost:\\ {': missing fields\nunable to parse 'host\\ \\=\\ \\\"my-vhost-name.local\\\"': missing fields"}
The very last line of the above output shows the parsing error message itself:
The related host and service definitions:
object Host "my-host.local" {
vars.apache.vhosts = [
host = "my-vhost-name.local"
apply Service "[DMZ] Apache vhost: " for (vhost in host.vars.apache.vhosts) {
check_command = "check_http"
display_name = "[DMZ] Apache vhost: " + vhost.host
assign where ...
Has anyone experienced this sort of issue?
Please help.
Regards,
Endre
