I’m a new user of Incinga and trying to get the InfluxDB2 integration working.
Logging seems to indicate it is doing something.
[2024-07-18 14:56:17 +0000] debug/Influxdb2Writer: Checkable 'xx.xxx.net!ping' adds to metric list:'ping,hostname=xx.xxx.net,service=ping,metric=rta crit=0.200000,min=0,unit="seconds",value=0.000645,warn=0.100000 1721314577'.
[2024-07-18 14:56:17 +0000] debug/Influxdb2Writer: Checkable 'xx.xxx.net!ping' adds to metric list:'ping,hostname=xx.xxx.net,service=ping,metric=pl crit=15,min=0,unit="percent",value=0,warn=5 1721314577'.
[2024-07-18 14:56:17 +0000] debug/Influxdb2Writer: Checkable 'xx.xxx.net!ping' adds to metric list:'ping,hostname=xx.xxx.net,service=ping acknowledgement=0i,current_attempt=1i,downtime_depth=0i,execution_time=4.107079,latency=0.000858,max_check_attempts=5i,reachable=true,state=0i,state_type=1i 1721314577'.
[2024-07-18 14:56:26 +0000] debug/Influxdb2Writer: Timer expired writing 3 data points
[2024-07-18 14:56:26 +0000] debug/Influxdb2Writer: Flushing data buffer to InfluxDB.
[2024-07-18 14:56:26 +0000] notice/Influxdb2Writer: Reconnecting to InfluxDB on host '127.0.0.1' port '8086'.
[2024-07-18 14:56:36 +0000] debug/Influxdb2Writer: Timer expired writing 0 data points
and the InfluxDB logging seems to show it is connecting OK.
Jul 18 14:58:26 nms influxd-systemd-start.sh[46254]: ts=2024-07-18T14:58:26.521080Z lvl=debug msg="user find by ID" log_id=0qT_apKW000 store=new took=0.035ms
Jul 18 14:58:26 nms influxd-systemd-start.sh[46254]: ts=2024-07-18T14:58:26.521362Z lvl=debug msg="org find" log_id=0qT_apKW000 store=new took=0.116ms
Jul 18 14:58:26 nms influxd-systemd-start.sh[46254]: ts=2024-07-18T14:58:26.521543Z lvl=debug msg="bucket find" log_id=0qT_apKW000 store=new took=0.124ms
Jul 18 14:58:26 nms influxd-systemd-start.sh[46254]: ts=2024-07-18T14:58:26.526715Z lvl=debug msg=Request log_id=0qT_apKW000 service=http method=POST host=127.0.0.1:8086 path=/api/v2/write query="bucket=icinga2&org=monitoring&precision=s" proto=HTTP/1.0 status_code=204 response_size=0 content_length=456 referrer= remote=127.0.0.1:60682 user_agent=Icinga authenticated_id=0d5d8a6c5acd4000 user_id=0d5d894ffecd4000 took=6.144ms
But nothing appears to be happening in the UI and the logs seem to indicate it is simply timing out?
I’ve gone through the docs but can’t see anyway to make the graphs appear in the UI - maybe i’m expecting them to appear but there is a step missing which isn’t obvious.
Thanks for any help received in advance.
