Influence default sort order
Is there a way to influence the sort order:
  • by setting a default somewhere
  • by modifying the links in, e.g., the HostGroup links
When I’m listing Host Groups, and then click on the column “xx Hosts” or “yy Services”, a new pane opens on the right side displaying those “xx Hosts” or “yy Services”.
But these are sorted by name. In IcingaWeb / IDO, they were sorted by severity. Can I change this behaviour somewhere?
you can only change it in the code directly
If you think that this is a feature that Icinga DB Web would benefit from, you could open a feature request in the repository :slight_smile:
