- Director version (System - About): not installed
- Icinga Web 2 version and modules (System - About): Icinga Web 2.12.1, incubator 0.22.0, ipl 0.5.0, reactbundle 0.9.0
- Icinga 2 version (
icinga2 --version):
- Operating System and version: Red Hat 7
- Webserver, PHP versions: Apache 2.4, PHP 7.3.33
I’m trying to install the vsphere plugin but incubator is showing up as:
When I try to re-enable it, I do not get a message:
Even weirder, when I click the module in Icinga Web I see this:
On the about page, its showing all my modules are being version 0.0.0:
Where can I check for errors?
Also, sometimes I get this error when trying to re-enable incubator:
Launching the run script /usr/share/icingaweb2/modules/vspheredb/run.php for module vspheredb failed with the following exception: Missing dependencies, please check
your incubator is broken, redownload the module
you can also delete ipl and reactbundle these two are deprecated.
Hello, did anything replace ipl and reactbundle?
I keep following the instructions here:
But even with version 0.21.0 I see this error:
ipl and react bundle are replaced icinga-php-library and icinga-php-thridparty and these two are packages
can you do
ls -la /usr/share/icingaweb2/modules/incubator
it seams that your webserver user has no read permissions on this folder.
what’s the output of
[root@icingadevapp02 ~]# ls -la /usr/share/icingaweb2/modules
total 40
drwxr-xr-x. 10 root root 4096 Jun 24 09:49 .
drwxr-xr-x. 7 root root 4096 Apr 11 09:51 ..
drwxr-xr-x. 6 root root 4096 Apr 11 09:51 doc
drwxr-xr-x. 7 root root 4096 Apr 15 10:31 icingadb
drwxr-x---. 6 root root 4096 Jun 24 11:52 incubator
drwxr-xr-x. 4 root root 4096 Apr 11 09:51 migrate
drwxr-xr-x. 6 root root 4096 Apr 11 09:51 monitoring
drwxr-xr-x. 4 root root 4096 Apr 11 09:51 setup
drwxr-xr-x. 5 root root 4096 Apr 11 09:51 translation
drwxr-xr-x. 10 root root 4096 Jun 21 14:38 vspheredb
total 28
drwxr-xr-x. 142 root root 4096 Apr 11 14:25 ..
drwxr-xr-x. 8 root root 4096 Apr 11 09:51 application
drwxr-xr-x. 5 root root 4096 Apr 11 09:51 doc
drwxr-xr-x. 10 root root 4096 Jun 24 09:49 modules
drwxr-xr-x. 6 root root 4096 Apr 11 09:51 public
drwxr-xr-x. 4 root root 4096 Apr 11 09:51 schema
in order for your webserver to read the content of the incubator folder, you need to
chmod -R 755 /usr/share/icingaweb2/modules/incubator
