I am trying to organize my AWS EC2 instances in Icinga using custom tags on the AWS instance.
I am successfully connected to my AWS regions and the EC2 instances are importing.
I have a job set to sync every two minutes
The issue I am having is the custom variables are not importing or the status of them isn’t updating.
Below are the relevant sections. Advice and guidance are appreciated!
Import Source Config
Sync Rule Properties
Sync Rule Modifiers
Job Config
Import Source Preview
Fields are showing
Host Report
Some fields missing
Status is incorrect
Another Host Report
Same import job, this host has the missing field
Any suggestions, ideas or pointers would be great!
If there is any config section I’ve missed to show, let me know.
