Hey there,
I want to export my data fields from the Director config and reimport it on another instance. The configuration basket does not support data fields, so I tried to do it via cli. The export
icingacli director export datafields > /tmp/datafields.json
works fine and I get a very nice JSON. When I want to import the fields with
icingacli director import importsources < /tmp/datafields.json
ends with following error:
ERROR: ErrorException in /usr/share/icingaweb2/modules/director/library/Director/Objects/ImportSource.php:92 with message: Undefined index: source_name
Director Version: 1.7.2
icingaweb2 Version: 2.8.2
icinga2 Version: 2.12.1-1
Thank you for your tips
Stephan
