Maybe it was too long ago I did this, but I’m trying to import a config basket for the cpu-usage from this source:
But I’m getting this error when doing the restore, anyone that has some input what I’m doing wrong?
in the basket there is a reference to a service template tpl-service-generic.
If you create that manually (with the command dummy), the basket should import
That is it! Thank you!!!
