When I try to create a import source in director I can create service, service set and service group but I can’t service apply.
Are there any way to import service apply rules?
Why there are not this option in import source?
An apply rule would be the same object but object_type set to apply, but be careful with service apply rules as they are not unique objects. This will give you recreate problems. I workaround this with service sets having the assign rule and then import the services to the service_set.
You are in true, apply rule is a special type of service. But I get this error:
I can only assign for applied objects or objects with native support for assigments, got object
My workaround is to create a Service Set and add the imported Services to it. So I have the assign rule on the Service Set (which could also be created by Import/Sync) and can simply create Services as objects.
Works pretty well for my use cases and is a clear configuration.
Thanks Dirk.
Only to double check I undertand correcly since you don’t use “apply for” if you what to check serveral instances, for example several apache, your service must be aware that must check serveral instances
Yes, I try to build it more in a way similar to this with multiple service sets:
Apache Default - assigned to all Apache Systems - containing default checks like service status, port 80 check, …
Apache SSL - assigned to All Apache Systems with SSL - checks like port 443, certificate, …
Apache FeatureA - additionally assigned to all where Feature A is used
Apache FeatureB - additionally assigned to all where Feature B is used
Apache ApplicationX - additionally assigned to all where Application X is used
Apache ApplicationY - additionally assigned to all where Application Y is used
Apache Port### - assigned where Apache runs on an additional port without a specific application
This should show the logic and is of course not a real world example, but I hope it is understandable. In some cases it is more complicated to build this logic then simply having an array and an apply for rule. But using the Director my goal is typically not the most simple but the most readable configuration.
And having a Serviceset, which has all the parts in its name a colleague or in my case a customer will likely search for, will result in him finding the set when he needs to add a service to it instead of creating a new one.
