Ifw - Invoke-IcingaCheckDiskHealth - Exclude mutiple disks without drive letter
it it possible to exclude multiple disks on the Invoke-IcingaCheckDiskHealth plugin? On Hyper-V Cluster sytems there where all the CSV mounted on every host. If the disks are not local it does not make sense to check on the windows system rather then on the storage system.
So i have to exclude all C:\ClusterStorage “Disks”.
Thanks.
