IfW Installation ends in SQLSERVER:\
Hello everyone
Strange behavior during IfW installation, the installer ends in this directory and Icinga shows this message.
Got JSON, but not an object, from IfW API on host 'localhost' port '5668': "SQL Server PowerShell provider error: Path SQLSERVER:\\Invoke-IcingaCheckMemory does not exist. Please specify a valid path."
Does anyone have any idea what the problem could be?
Thank you!
Thnak you for the topic.
Could it be that there is some sort of profile being loaded in the background, automatically loading SQL?
Icinga for Windows itself is only “manipulating” the shell to print
icinga>
If you explicit run the
icinga -Shell
command. But other than that, Icinga for Windows isn’t doing anything there.
