Not sure if this is a bug, a limitation or just not a feature, but I noticed something trying to get some historical data out of IDO today.
The icinga_eventhandlers table only shows event handlers that ran on the masters, not the clients. For example, that event_index-lock-remover
handler runs quite often.
icinga=# select object_id,name1 from icinga_objects where name1 like('event_%') order by object_id;
object_id | name1
411 | event_test_ido_check
412 | event_index-lock-remover
2704 | event_ido-failover
2705 | event_test_output
2706 | event_flagdestroyer
24754 | event_ntpd-starter
24755 | event_unix-process-handler
24757 | event_linux-log-cleanup-handler
48580 | event_catalina-log-nixer
55205 | event_solaris-svc-restart
55206 | event_event_ssh
55963 | event_test-event
56200 | event_array-index-restart
56831 | event_average-request-count
57140 | event_filenotfound-announce
57493 | event_pagerduty-api
59475 | event_dangerous-service-restart
59778 | event_[redacted]
63491 | event_test-downtime-event
67302 | event_usernotfound-announce
72068 | event_cf-log-handler
78803 | event_mailflood-flag-destroyer
80611 | event_service-macros
80613 | event_rabbitmq_event_fetch
80707 | event_hostalive-announce
(25 rows)
icinga=# select distinct command_object_id from icinga_eventhandlers order by command_object_id;
command_object_id
2705
2706
24754
55205
55963
56831
57140
59475
78803
80613
80707
(11 rows)
So event handlers specific to client nodes have never been recorded here. Presently looking around for another way to scrape this data and will likely throw a little note here for future observers, but thought to run it by here before putting in something on github. Is this expected? Thanks!
