Icngaweb2 history section not working
Hello.
I am using Ubuntu 18.04, Icinga2 2.11, icingaweb2 2.8, php 7.4. But when I click on history section, nothing shows.
Could you help me on this case.
Thank you much.
Does the history of a single host/service work?
How do the log files look?
/var/log/icingaweb2/icingaweb2.log
/var/log/apache2/error.log
http://yourmonitoringhost/icingaweb2/list/applicationlog
Hi.
Yep, It works
It is normal. These logs show information about when I connect backend DB.
Which database are you using?
If it’s MySQL, you may enable the slow query log and check if there are queries appearing that start with the following:
SELECT eh.id, eh.host_name, eh.host_display_name, eh.service_description,
eh.service_display_name, eh.object_type, eh.timestamp, eh.state, eh.output,
eh.type FROM (SELECT
Please confirm this if that’s the case. (And be sure to include the database version as well)
Hello.
I am using 10.3.13-MariaDB MariaDB Server.
I think it is due to slow query. I have 3000 hosts and 12000 services. I try with another setup with 100 hosts and 400 services then I can see data from history session. Any recommends on this case? Thank you much.
