Icnga2 webhook o365 teams channel deprecated
we use webhook notifications via json with perl script “modified version of nagios-mstreams.pl for icinga2 without env’s”.
ms teams comments by message since this week:
Action Required: O365 connectors within Teams will be deprecated and notifications from this service will stop. about the timing and how the Workflows app provides a more flexible and secure experience. If you want to continue receiving these types of messages, you can use a workflow to post messages from a webhook request.
has anyone a workflow or idea how we can send messages after ms stop?
I try to switch from icinga2-teams-notification :: Icinga Exchange to Icinga2-teams-adaptive-notifications :: Icinga Exchange and use the new Webhook URL provided by the predefined Workflow - generated by clicking on the link in the comment to the massage.
But I didn’t succeed before the weekend came.
The version used also webhook, what disabled in October.
I think we need new/other plugin with api to ms automate and workflows.
I think the version uses a message that would be compatible if used with a Workflow based webhook. So 2 things need to change message format and m365 webhook to Workflow webhook.
yay. changing APIs is always fun …
Reason was:
I create Workflow “Post to a channel when a webhook request is received” into MS Power Automate. That create a new API URL. I create new python notifications script for icinga2. The script generated a JSON for API and send data via python POST methode.
hi, would you like to share your script?
Hi all,
can you share a solution with us @lini-linux ?
It seems to be a serious issue.
teams-host-notification.py
#!/usr/bin/env python3
import requests, os, sys
import urllib3, argparse
urllib3.disable_warnings()
parser = argparse.ArgumentParser()
parser.add_argument('-4', help='hostaddress4')
parser.add_argument('-6', help='hostaddress6')
parser.add_argument('-H', help='hostaddress')
parser.add_argument('-b', help='author')
parser.add_argument('-c', help='comment')
parser.add_argument('-d', help='datetime')
parser.add_argument('-l', help='hostname')
parser.add_argument('-n', help='hostdisplayname')
parser.add_argument('-o', help='output')
parser.add_argument('-p', help='pager')
parser.add_argument('-s', help='state')
parser.add_argument('-t', help='type')
parser.add_argument('-v', help='logtosyslog')
args = parser.parse_args()
hostaddress = args.H
author = args.b
hostname = args.l
comment = args.c
hostdisplayname = args.n
state = args.s
output = args.o
boturl = args.p
icingaweburl = 'http://10.32.0.10/icingaweb2'
grafanaweburl = 'http://10.32.0.20:3000/d/A2TT33N7z'
if state == 'OK':
  color = 'good'
elif state == 'UP':
  color = 'good'
elif state == 'WARNING':
  color = 'warning'
elif state == 'DOWN':
  color = 'attention'
elif state == 'CRITICAL':
  color = 'attention'
elif state == 'UNKNOWN':
  color = 'light'
elif state == 'UNREACHABLE':
  color = 'light'
else:
  color = 'dark'
headers = {
    	'Content-Type': 'application/json;charset=utf-8',
json_data = {
        "type":"message",
        "attachments":[
                "contentType":"application/vnd.microsoft.card.adaptive",
                "contentUrl":"null",
                "content":{
                    "$schema":"http://adaptivecards.io/schemas/adaptive-card.json",
                    "type":"AdaptiveCard",
                    "version":"1.2",
                    "title":"SSC Monitoring",
                    "body":[
                          "type": "TextBlock",
                          "size": "Large",
                          "weight": "Bolder",
                          "text": hostdisplayname+" is "+state,
                          "color": color,
                          "text": "**Host**: "+hostaddress+" ",
                          "text": "**Details**: "+output+" ",
                          "text": "**Comment**: "+comment+" ",
                          "text": "**Author**: "+author+" ",
                    "actions": [
                        "type": "Action.OpenUrl",
                        "url": icingaweburl+"/monitoring/host/show?host="+hostname+"",
                        "title": "Open in Monitoring"
                        "url": grafanaweburl+"/icinga2?var-hostname="+hostname+"&orgId=1&fullscreen",
                        "title": "Open in Grafana"
response = requests.post(
    boturl,
    headers=headers,
    json=json_data,
    verify=False
Hi @lini-linux
it would be really cool if you would also post the teams-service-notification.py script here :eyes:
If such a thing exists.
Thank you very much!
You can copy from host and modify :wink:
parser.add_argument('-e', help='servicename')
parser.add_argument('-u', help='servicedisplayname')
author = args.b
hostname = args.l
comment = args.c
state = args.s
output = args.o
servicename = args.e
boturl = args.p
servicedisplayname = args.u
if state == 'OK':
  color = 'good'
elif state == 'UP':
  color = 'good'
  color = 'warning'
  color = 'attention'
  color = 'attention'
  color = 'light'
  color = 'light'
else:
  color = 'dark'
headers = {
json_data = {
        "type":"message",
        "attachments":[
                "content":{
                    "version":"1.2",
                    "body":[
                          "size": "Large",
                          "weight": "Bolder",
                          "text": hostdisplayname+": "+servicename+" is "+state,
                          "color": color,
                          "text": "**Service**: "+servicename+" ",
                    "actions": [
                        "url": icingaweburl+"/monitoring/service/show?host="+hostname+"&service="+servicename+"",
    boturl,
    headers=headers,
    json=json_data,
    verify=False
Hi @lini-linux
I got the following error:
Traceback (most recent call last):
  File "./teams-service-notification.py", line 83, in <module>
TypeError: must be str, not NoneType
The command was this one:
./teams-service-notification.py '-4' '192.168.0.2' '-6' '' '-b' 'USER' '-c' 'test' '-d' '2024-10-16 09:47:07 +0200' '-e' 'DUMMY TEST ADAPTIVE NOTIFICATIONS ----IGNORE-ME---' '-l' 'srv01.local' '-n' 'srv01' '-o' 'PROCS CRITICAL: 0 processes with command name 'dummy' ' '-p' 'https://WEBHOOKURL' '-s' 'CRITICAL' '-t' 'CUSTOM' '-u' 'DUMMY TEST ADAPTIVE NOTIFICATIONS ----IGNORE-ME---'
Did you guys encounter the same problem ?
/edit:
I noticed when I replace ‘-4’ with ‘-H’ it works:
./teams-service-notification.py '-H' '192.168.0.2' '-6' '' '-b' 'USER' '-c' 'test' '-d' '2024-10-16 09:47:07 +0200' '-e' 'DUMMY TEST ADAPTIVE NOTIFICATIONS ----IGNORE-ME---' '-l' 'srv01.local' '-n' 'srv01' '-o' 'PROCS CRITICAL: 0 processes with command name 'dummy' ' '-p' 'https://WEBHOOKURL' '-s' 'CRITICAL' '-t' 'CUSTOM' '-u' 'DUMMY TEST ADAPTIVE NOTIFICATIONS ----IGNORE-ME---'
Why is there no ‘-H’ argument passed to the notification command ?
I added the argument “-H” with value $host.address$ to the command definition and it works now:
Now the only problem which is left is that the message in teams looks like this:
As ou can see the message does not use the complete width. Is it possible to modify the message so it shows completely ?
For example like the old message with the old soon to be deprecated webhook:
This is how the workflow is setup:
I have changed the design of the Adaptive Card and adapted the link for IcingaDB.
With the imageurl variable you can display an image with the corresponding color (Important: The image must be accessible from the Internet for teams).
The author and comment are only displayed if you have really commented something.
With “msteams”: {“width”: “Full”} the maximum width in teams is used.
Hope this helps someone
Service
from datetime import datetime
current_datetime = datetime.now()
current_datetime_str = current_datetime.strftime("%d.%m.%Y %H:%M:%S")
parser.add_argument('-i', help='icingaweburl')
parser.add_argument('-g', help='grafanaurl')
author = args.b
hostname = args.l
comment = args.c
state = args.s
output = args.o
boturl = args.p
notificationtype = args.t
icingaweburl = args.i
grafanaweburl = args.g
if state == 'OK':
  color = 'good'
  imageurl = "https://i.imgur.com/yLPKBlF.png"
elif state == 'UP':
  color = 'good'
  color = 'warning'
  imageurl = "https://i.imgur.com/GIv0R4o.png"
  color = 'attention'
  imageurl = "https://i.imgur.com/C2B8moA.png"
  color = 'attention'
  color = 'light'
  imageurl = "https://i.imgur.com/ALr2Cwx.png"
  color = 'light'
else:
  color = 'dark'
# Check if type is custom
if comment or author:
    iscomment = "true"
else:
    iscomment = "false"
headers = {
json_data = {
        "type":"message",
        "attachments":[
                "content":{
                    "version":"1.3",
                    "title":"Monitoring",
                    "msteams": {
                        "width": "Full"
                    "body":[
                            "type": "Container",
                            "items": [
                                    "text": notificationtype,
                                    "weight": "bolder",
                                    "size": "medium",
                                    "isSubtle": "true",
                                    "spacing": "None"
                                    "text": hostdisplayname,
                                    "weight": "bolder",
                                    "size": "large",
                                    "spacing": "None"
                                    "type": "ColumnSet",
                                    "columns": [
                                            "type": "Column",
                                            "width": "auto",
                                            "items": [
                                                    "type": "Image",
                                                    "url": imageurl,
                                                    "altText": state,
                                                    "size": "small",
                                                    "style": "person"
                                            "type": "Column",
                                            "width": "stretch",
                                            "items": [
                                                    "type": "RichTextBlock",
                                                    "inlines": [
                                                            "type": "TextRun",
                                                            "text": servicedisplayname,
                                                            "weight": "bolder",
                                                            "wrap": "true"
                                                            "type": "TextRun",
                                                            "text": " is ",
                                                            "weight": "bolder",
                                                            "wrap": "true",
                                                            "isSubtle": "true"
                                                            "type": "TextRun",
                                                            "text": state,
                                                            "weight": "bolder",
                                                            "wrap": "true"
                                                "spacing": "none",
                                                "text": current_datetime_str,
                                                "isSubtle": "true",
                                                "wrap": "true"
                            "items": [
                                    "inlines": [
                                            "type": "TextRun",
                                            "text": output
                                    "type": "FactSet",
                                    "isVisible": iscomment,
                                    "facts": [
                                            "title": "Comment:",
                                            "value": comment
                                            "title": "Author:",
                                            "value": author
                    "actions": [
                        "url": icingaweburl+"/icingadb/service?name="+servicename+"&host.name="+hostname+"",
                        "title": "View"
    boturl,
    headers=headers,
    json=json_data,
    verify=False
Host
author = args.b
hostname = args.l
comment = args.c
state = args.s
output = args.o
boturl = args.p
if state == 'OK':
  color = 'good'
elif state == 'UP':
  color = 'good'
  color = 'warning'
  color = 'attention'
  color = 'attention'
  color = 'light'
  color = 'light'
else:
  color = 'dark'
    iscomment = "true"
else:
    iscomment = "false"
headers = {
json_data = {
        "type":"message",
        "attachments":[
                "content":{
                    "version":"1.3",
                    "msteams": {
                        "width": "Full"
                    "body":[
                            "items": [
                                    "weight": "bolder",
                                    "size": "medium",
                                    "isSubtle": "true",
                                    "spacing": "None"
                                    "columns": [
                                            "type": "Column",
                                            "width": "auto",
                                            "items": [
                                                    "type": "Image",
                                                    "url": imageurl,
                                                    "altText": state,
                                                    "size": "small",
                                                    "style": "person"
                                            "type": "Column",
                                            "width": "stretch",
                                            "items": [
                                                    "inlines": [
                                                            "type": "TextRun",
                                                            "weight": "bolder",
                                                            "size": "large",
                                                            "wrap": "true"
                                                            "type": "TextRun",
                                                            "text": " is ",
                                                            "weight": "bolder",
                                                            "wrap": "true",
                                                            "isSubtle": "true"
                                                            "type": "TextRun",
                                                            "text": state,
                                                            "weight": "bolder",
                                                            "size": "large",
                                                            "wrap": "true"
                                                "spacing": "none",
                                                "isSubtle": "true",
                                                "wrap": "true"
                            "items": [
                                    "inlines": [
                                            "type": "TextRun",
                                            "text": output
                                    "type": "FactSet",
                                    "facts": [
                                            "value": comment
                                            "title": "Author:",
                                            "value": author
                    "actions": [
                        "url": icingaweburl+"/icingadb/host?name="+hostname+"",
                        "title": "View"
    boturl,
    headers=headers,
    json=json_data,
    verify=False
I there !
How do you call python’s scripts when notification is sending ?
Thanks a lot
You define it in the director under commands:
I don’t have director installed yet du to historical instance.
but I did it with configuration and It’s working.
into commands.conf
object NotificationCommand "teams-service-notification-command" {
  command = [ "path/to/teams-service-notification.py" ]
  arguments += {
    "-H" = {
      value = "$host.address$"
      description = "Adresse de l'hôte"
    "-l" = {
      value = "$host.name$"
      description = "Nom de l'hôte"
    "-n" = {
      value = "$host.display_name$"
      description = "Nom affiché de l'hôte"
    "-s" = {
      value = "$service.state$"
      description = "État du service"
    "-o" = {
      value = "$service.output$"
      description = "Sortie du service"
    "-p" = {
      value = "$user.vars.teams_webhook_url$"
      description = "URL du webhook Teams"
    "-e" = {
      value = "$service.display_name$"
      description = "Nom du service"
    "-t" = {
      value = "$notification.type$"
      description = "Type de notification"
  env = {
    NOTIFICATIONTYPE = "$notification.type$"
    SERVICEDESC = "$service.display_name$"
    SERVICESTATE = "$service.state$"
    SERVICEOUTPUT = "$service.output$"
    HOSTALIAS = "$host.display_name$"
    HOSTADDRESS = "$address$"
object NotificationCommand "teams-notification-command" {
  command = [ "path/to/teams-host-notification.py" ]
  arguments += {
    "-H" = {
    "-l" = {
    "-n" = {
    "-s" = {
      value = "$host.state$"
      description = "État de l'hôte"
    "-o" = {
      value = "$host.output$"
      description = "Sortie de l'hôte"
    "-p" = {
    "-t" = {
  env = {
    HOSTSTATE = "$host.state$"
    HOSTOUTPUT = "$host.output$"
And into users.conf
object User "teams" {
  import "generic-user"
  display_name = "Teams User"
  vars.teams_webhook_url = "Teams webooh URL here"
Hosts.conf
vars.notify_users = [ "teams" ]
vars.notification.teams = true
And each host or service I wan’t notifications I had
vars.notification.teams = true into config
I don’t know if anyone would find this useful but i converted the python script to bash.
#!/bin/bash
# Function to get current datetime
current_datetime=$(date +"%d.%m.%Y %H:%M:%S")
# Parse arguments
while getopts "4:6:H:b:c:d:e:l:n:o:p:s:t:u:v:i:g:" opt; do
  case $opt in
    4) hostaddress4=$OPTARG ;;
    6) hostaddress6=$OPTARG ;;
    H) hostaddress=$OPTARG ;;
    b) author=$OPTARG ;;
    c) comment=$OPTARG ;;
    d) datetime=$OPTARG ;;
    e) servicename=$OPTARG ;;
    l) hostname=$OPTARG ;;
    n) hostdisplayname=$OPTARG ;;
    o) output=$OPTARG ;;
    p) boturl=$OPTARG ;;
    s) state=$OPTARG ;;
    t) notificationtype=$OPTARG ;;
    u) servicedisplayname=$OPTARG ;;
    v) logtosyslog=$OPTARG ;;
    i) icingaweburl=$OPTARG ;;
    g) grafanaweburl=$OPTARG ;;
  esac
done
# Determine color and image URL based on state
case $state in
  OK|UP)
    color="good"
    imageurl="https://i.imgur.com/yLPKBlF.png"
  WARNING)
    color="warning"
    imageurl="https://i.imgur.com/GIv0R4o.png"
  DOWN|CRITICAL)
    color="attention"
    imageurl="https://i.imgur.com/C2B8moA.png"
  UNKNOWN|UNREACHABLE)
    color="light"
    imageurl="https://i.imgur.com/ALr2Cwx.png"
    color="dark"
esac
if [ -n "$comment" ] || [ -n "$author" ]; then
  iscomment="true"
else
  iscomment="false"
fi
# Create JSON payload
json_data=$(cat <<EOF
  "type": "message",
  "attachments": [
      "contentType": "application/vnd.microsoft.card.adaptive",
      "contentUrl": "null",
      "content": {
        "\$schema": "http://adaptivecards.io/schemas/adaptive-card.json",
        "type": "AdaptiveCard",
        "version": "1.3",
        "title": "Monitoring",
        "msteams": {
          "width": "Full"
        "body": [
            "items": [
                "text": "$notificationtype",
                "weight": "bolder",
                "size": "medium",
                "isSubtle": "true",
                "spacing": "None"
                "text": "$hostdisplayname",
                "weight": "bolder",
                "size": "large",
                "spacing": "None"
                "columns": [
                    "type": "Column",
                    "width": "auto",
                    "items": [
                        "type": "Image",
                        "url": "$imageurl",
                        "altText": "$state",
                        "size": "small",
                        "style": "person"
                    "type": "Column",
                    "width": "stretch",
                    "items": [
                        "inlines": [
                            "type": "TextRun",
                            "text": "$servicedisplayname",
                            "weight": "bolder",
                            "wrap": "true"
                            "type": "TextRun",
                            "text": " is ",
                            "weight": "bolder",
                            "wrap": "true",
                            "isSubtle": "true"
                            "type": "TextRun",
                            "text": "$state",
                            "weight": "bolder",
                            "wrap": "true"
                        "spacing": "none",
                        "text": "$current_datetime",
                        "isSubtle": "true",
                        "wrap": "true"
            "items": [
                "inlines": [
                    "type": "TextRun",
                    "text": "$output"
                "type": "FactSet",
                "isVisible": $iscomment,
                "facts": [
                    "value": "$comment"
                    "title": "Author:",
                    "value": "$author"
        "actions": [
            "url": "$icingaweburl/icingadb/service?name=$servicename&host.name=$hostname",
            "title": "View"
EOF
# Send the Adaptive Card
curl -H "Content-Type: application/json;charset=utf-8" -d "$json_data" "$boturl"
