I am currently finishing a Master - Satellite - Setup. The two nodes are already connected (using the node wizard on the satellite), as I found out from my icinga2-logs. I furthermore configured icingaweb2 on the satellite and am using director on the master.
When going through the graphical icingaweb2 node wizard on the satellite(!), I had to configure multiple dbs, which I thought would by synchronized automatically from the master - together with further add-ons like the director. So I guess I am still missing a point about the synchronization process. Apart from this missunderstanding, I cannot find my satellite on the master’s icingaweb2-frontend.
So, let me break down my doubts into two independent questions: 1. How do I get to show up my satellite on my master’s icingaweb2? And 2. What do I need to configure in my satellite’s icingaweb2 and what is being synced from my master? In case I need to manually add the host to my master’s icingaweb2, is it possible to make this process automatic using director?
Any help is very much appreciated, I am kind of lost at this point. Thanks in advance!
