Hi guys,
I recently updated the OS of my working Icinga2 setup to Ubuntu 22 LTS.
Icinga generally works well (I get lots of mails when something is wrong with my landscape etc), but Icingaweb2 stopped working. For my understanding, this is exactly the same issue which is also discussed here Issues · Icinga/icingaweb2 · GitHub
Deprecated: Return type of Icinga\Application\Libraries::getIterator() should either be compatible with IteratorAggregate::getIterator(): Traversable, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in /usr/share/php/Icinga/Application/Libraries.php on line 20
Deprecated: Return type of Icinga\Application\Config::count() should either be compatible with Countable::count(): int, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in /usr/share/php/Icinga/Application/Config.php on line 125
Deprecated: Return type of Icinga\Application\Config::current() should either be compatible with Iterator::current(): mixed, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in /usr/share/php/Icinga/Application/Config.php on line 145
Deprecated: Return type of Icinga\Application\Config::next() should either be compatible with Iterator::next(): void, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in /usr/share/php/Icinga/Application/Config.php on line 175
Deprecated: Return type of Icinga\Application\Config::key() should either be compatible with Iterator::key(): mixed, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in /usr/share/php/Icinga/Application/Config.php on line 165
Deprecated: Return type of Icinga\Application\Config::valid() should either be compatible with Iterator::valid(): bool, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in /usr/share/php/Icinga/Application/Config.php on line 155
Deprecated: Return type of Icinga\Application\Config::rewind() should either be compatible with Iterator::rewind(): void, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in /usr/share/php/Icinga/Application/Config.php on line 135
Deprecated: Return type of Icinga\Web\Session\SessionNamespace::getIterator() should either be compatible with IteratorAggregate::getIterator(): Traversable, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in /usr/share/php/Icinga/Web/Session/SessionNamespace.php on line 35
Deprecated: Return type of Icinga\Authentication\AuthChain::current() should either be compatible with Iterator::current(): mixed, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in /usr/share/php/Icinga/Authentication/AuthChain.php on line 200
Deprecated: Return type of Icinga\Authentication\AuthChain::next() should either be compatible with Iterator::next(): void, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in /usr/share/php/Icinga/Authentication/AuthChain.php on line 220
Deprecated: Return type of Icinga\Authentication\AuthChain::key() should either be compatible with Iterator::key(): mixed, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in /usr/share/php/Icinga/Authentication/AuthChain.php on line 210
Deprecated: Return type of Icinga\Authentication\AuthChain::valid() should either be compatible with Iterator::valid(): bool, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in /usr/share/php/Icinga/Authentication/AuthChain.php on line 231
Deprecated: Return type of Icinga\Authentication\AuthChain::rewind() should either be compatible with Iterator::rewind(): void, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in /usr/share/php/Icinga/Authentication/AuthChain.php on line 189
Fatal error: Uncaught ErrorException: Uncaught Zend_Controller_Response_Exception: Cannot send headers; headers already sent in /usr/share/php/Icinga/Authentication/AuthChain.php, line 22 in /usr/share/icinga-php/vendor/vendor/shardj/zf1-future/library/Zend/Controller/Response/Abstract.php:323 Stack trace: #0 /usr/share/icinga-php/vendor/vendor/shardj/zf1-future/library/Zend/Controller/Response/Abstract.php(148): Zend_Controller_Response_Abstract->canSendHeaders() #1 /usr/share/php/Icinga/Web/Response.php(356): Zend_Controller_Response_Abstract->setRedirect() #2 /usr/share/php/Icinga/Web/Response.php(407): Icinga\Web\Response->prepare() #3 /usr/share/icinga-php/vendor/vendor/shardj/zf1-future/library/Zend/Controller/Response/Abstract.php(768): Icinga\Web\Response->sendHeaders() #4 /usr/share/icinga-php/vendor/vendor/shardj/zf1-future/library/Zend/Controller/Front.php(992): Zend_Controller_Response_Abstract->sendResponse() #5 /usr/share/php/Icinga/Application/Web.php(304): Zend_Controller_Front->dispatch() #6 /usr/share/php/Icinga/Application/webrouter.php(107): Icinga\Application\Web->dispatch() #7 /usr/share/icingaweb2/public/index.php(4): require_once('...') #8 {main} thrown in /usr/share/icinga-php/vendor/vendor/shardj/zf1-future/library/Zend/Controller/Response/Abstract.php:323 Stack trace: #0 [internal function]: Icinga\Application\Web->Icinga\Application\{closure}() #1 {main} Next Zend_Controller_Exception: Uncaught Zend_Controller_Response_Exception: Cannot send headers; headers already sent in /usr/share/php/Icinga/Authentication/AuthChain.php, line 22 in /usr/share/icinga-php/vendor/vendor/shardj/zf1-future/library/Zend/Controller/Response/Abstract.php:323 Stack trace: #0 /usr/share/icinga-php/vendor/vendor/shardj/zf1-future/library/Zend/Controller/Response/Abstract.php(148): Zend_Controller_Response_Abstract->canSendHeaders() #1 /usr/share/php/Icinga/Web/Response.php(356): Zend_Controller_Response_Abstract->setRedirect() #2 /usr/share/php/Icinga/Web/Response.php(407): Icinga\Web\Response->prepare() #3 /usr/share/icinga-php/vendor/vendor/shardj/zf1-future/library/Zend/Controller/Response/Abstract.php(768): Icinga\Web\Response->sendHeaders() #4 /usr/share/icinga-php/vendor/vendor/shardj/zf1-future/library/Zend/Controller/Front.php(992): Zend_Controller_Response_Abstract->sendResponse() #5 /usr/share/php/Icinga/Application/Web.php(304): Zend_Controller_Front->dispatch() #6 /usr/share/php/Icinga/Application/webrouter.php(107): Icinga\Application\Web->dispatch() #7 /usr/share/icingaweb2/public/index.php(4): require_once('...') #8 {main} thrown#0 [internal function]: Icinga\Application\Web->Icinga\Application\{closure}() #1 {main} in /usr/share/icinga-php/vendor/vendor/shardj/zf1-future/library/Zend/Controller/Plugin/Broker.php:262 Stack trace: #0 /usr/share/icinga-php/vendor/vendor/shardj/zf1-future/library/Zend/Controller/Front.php(923): Zend_Controller_Plugin_Broker->routeShutdown() #1 /usr/share/php/Icinga/Application/Web.php(471): Zend_Controller_Front->dispatch() #2 [internal function]: Icinga\Application\Web->Icinga\Application\{closure}() #3 {main} thrown in /usr/share/icinga-php/vendor/vendor/shardj/zf1-future/library/Zend/Controller/Plugin/Broker.php on line 262
I made sure that Icinga as well as Icingaweb2 is up-to-date (installed via repository).
Many thanks in advance!
- Icinga Web 2 version:
2.12.1-1+ubuntu22.04 - Used modules and their versions (System - About): From aptitude:
- icingaweb2-module-doc:
2.11.4-5+ubuntu22.04 - icingaweb2-module-monitoring:
- Web browser used: latest version of Safari/Firefox
- Icinga 2 version used (
icinga2 --version):r2.14.1-1 - PHP version used (
php --version):PHP 8.1.2-1ubuntu2.14withZend Engine v4.1.2 - Server operating system and version: Ubuntu 22.04 LTS
