lobr
(lobr)
September 1, 2022, 12:24pm
1
on icinga2 I enabled the module “businessprocess” (see: icingaweb2-module-businessprocess/doc/02-Installation.md at main · Icinga/icingaweb2-module-businessprocess · GitHub )
Afterwards the WebUI looks very different. Even after a reboot of the Linux server or after disabling the module again, it’s still the same. Is there a way to bring CSS back?
Dependencies installed:
icinga-php-library.noarch 0.9.1-1.el7.icinga
icinga-php-thirdparty.noarch 0.11.0-1.el7.icinga
monitoring 2.9.6
Not installed
icingadb >=1.0.0 (not installed)
Icinga Web 2 Version
2.9.6
Git commit
e702d933e15b0907628091a03741baff1b6074df
PHP Version
7.3.29
Git commit date
2022-03-08
Copyright
© 2013-2022 Icinga GmbH
Loaded Libraries
|Name|Version|
|icinga/icinga-php-library|0.9.1|
|icinga/icinga-php-thirdparty|0.11.0|
Loaded Modules
Screenshot of GUI
lobr
(lobr)
September 1, 2022, 2:31pm
2
I found the solution. For some reason icinga-php-library musn’t be higher than 0.8.0
nilmerg
(Johannes Meyer)
September 2, 2022, 6:25am
3
Since you didn’t mention the version of businessprocess you tried, I have to guess. Version 2.3.0 is indeed not compatible with the newest versions of the libraries, though there is v2.3.1 which is. And v2.4.0 of course.
lobr
(lobr)
September 2, 2022, 7:39am
4
I am using the most recent version 2.4.0.
nilmerg
(Johannes Meyer)
September 2, 2022, 8:03am
5
This should not happen then. Please upgrade icinga-php-library again and show the output of /icingaweb2/css/icinga.css. There might be just an error or some CSS and the error is at the very end (scroll down).
lobr
(lobr)
September 2, 2022, 8:42am
6
This file does not exist…
Even if you meant /usr/share/icingaweb2
nilmerg
(Johannes Meyer)
September 2, 2022, 9:07am
7
That’s a route. http://localhost/icingaweb2/...
lobr
(lobr)
September 2, 2022, 9:12am
8
Here it is:
Operation on an invalid type
#0 /usr/share/icingaweb2/library/vendor/lessphp/lib/Less/Tree/Expression.php(51): Less_Tree_Operation->compile(Object(Less_Environment))
#1 /usr/share/icingaweb2/library/vendor/lessphp/lib/Less/Tree/Call.php(44): Less_Tree_Expression->compile(Object(Less_Environment))
#2 /usr/share/icingaweb2/library/vendor/lessphp/lib/Less/Tree/Expression.php(51): Less_Tree_Call->compile(Object(Less_Environment))
#3 /usr/share/icingaweb2/library/vendor/lessphp/lib/Less/Tree/Value.php(26): Less_Tree_Expression->compile(Object(Less_Environment))
#4 /usr/share/icingaweb2/library/vendor/lessphp/lib/Less/Tree/Rule.php(73): Less_Tree_Value->compile(Object(Less_Environment))
#5 /usr/share/icingaweb2/library/vendor/lessphp/lib/Less/Tree/Ruleset.php(91): Less_Tree_Rule->compile(Object(Less_Environment))
#6 /usr/share/icingaweb2/library/vendor/lessphp/lib/Less/Tree/Ruleset.php(91): Less_Tree_Ruleset->compile(Object(Less_Environment))
#7 /usr/share/icingaweb2/library/vendor/lessphp/lib/Less/Parser.php(185): Less_Tree_Ruleset->compile(Object(Less_Environment))
#8 /usr/share/icingaweb2/library/vendor/lessphp/lessc.inc.php(130): Less_Parser->getCss()
#9 /usr/share/php/Icinga/Web/LessCompiler.php(274): lessc->compile('\n\n:root, :host ...')
#10 /usr/share/php/Icinga/Web/StyleSheet.php(226): Icinga\Web\LessCompiler->render()
#11 /usr/share/php/Icinga/Web/StyleSheet.php(264): Icinga\Web\StyleSheet->render(false)
#12 /usr/share/php/Icinga/Application/webrouter.php(59): Icinga\Web\StyleSheet::send()
#13 /usr/share/icingaweb2/public/index.php(4): require_once('/usr/share/php/...')
#14 {main}
.. 07143em;
vertical-align: 0.05357em; }
.fa-lg {
font-size: 1.25em;
line-height: 0.05em;
vertical-align: -0.075em; }
.fa-xl {
font-size: 1.5em;
line-height: 0.04167em;
vertical-align: -0.125em; }
.fa-2xl {
font-size: 2em;
line-height: 0.03125em;
vertical-align: -0.1875em; }
.fa-fw {
text-align: center;
width: 1.25em; }
.fa-ul {
list-style-type: none;
margin-left: var(--fa-li-margin, 2.5em);
padding-left: 0; }
.fa-ul > li {
position: relative; }
.fa-li {
!! left: calc(var(--fa-li-width, 2em) * -1);
position: absolute;
text-align: center;
width: var(--fa-li-width, 2em);
line-height: inherit; }
.fa-border {
border-color: var(--fa-border-color, #eee);
border-radius: var(--fa-border-radius, 0.1em);
border-style: var(--fa-border-style, solid);
border-width: var(--fa-border-width, 0.08em);
padding: var(--fa-border-padding, 0.2em 0.25em 0.15em); }
.fa-pull-left {
float: left;
margin-right: var(--fa-pull-margin, 0.3em); }
.fa-pull-
icinga_with_icinga-php-library-0.9.1-1.el7.icinga.noarch.zip (1.0 KB)
nilmerg
(Johannes Meyer)
September 2, 2022, 11:45am
9
ah, you should upgrade Icinga Web to v2.9.7. Then the newest icinga-php-library works fine.
