Icingaweb2 host history events not shown
I have a problem with icingaweb2 version 2.7.0.
The history of the services and hosts is not updated.
I have checked the table icinga_statehistory and the data is there but on the web interface it’s not displayed anymore, only some old entries, i guess this happened after upgrading icingaweb2.
Can you please advice or maybe a workaround for this problem ?
Thank you in advance !
This is a know bug.
Thank you for your answer.
Do you know if there is an incoming fix for this soon ?
If not is it possible to downgrade to version 2.6.3 ?
Subscribe to issue notifications to stay uptodate. Developers are working on it already.
