Trying to pull the container, doesnt work:
PS D:\docker_containers\icinga2> docker pull icinga/icingaweb2
Using default tag: latest
Error response from daemon: manifest for icinga/icingaweb2:latest not found: manifest unknown: manifest unknown
Anyone else? Icinga on docker dead?
ejfv
(Emilio José Flores Vicente)
2
Hi Daneil,
The problem is the tag, there are no latest tag.
I use master :
docker pull icinga/icingaweb2:master
I see two tags master and database-configuration-backend-3770
But I don’t know the meaning may be anyone can help us
Best regards,
Emilio J.
True, tag is missing. I would expect such a project to have the containers clean…
Emilio, how did you manage the configuration of the icingaweb2 container? I see no documentation anywhere, how to connect to the database etc.
ejfv
5
First note that you must configure a volume for /data in order that configuration will be persistent.
I use web wizard. It’s a easy way.
Best regards,
Emilio J.
So, I see that /data is mentioned in the Icinga2 Conatiner. Is that true for icingaweb2, too? And what is Web-Wizzard? You got a link?
ejfv
7
Yes, behavior is similar to icinga2 master.
If you try to connect to web and it’s not configured you get the wizard.
Ah, I see. Thx. I still don’t really understand the config of the Icinga2 container, but we’ll see…
rsx
(Roland Sommer)
9
Did you manage to install the db connection for icingaweb2? What about IDO? How did you manage that?
Sorry, I gave up. Install is now standard / traditional on a RHEL
