Hello Community,
I’ve written an own icingaweb2 director property modifier.
So if I use this modifier manually (that means if I click on my sync rule and then on “trigger run”) the modifier works really nice.
But if I create a job, which runs that import job, and wait until the job triggers the import, I get the following message:
So the question is:
Why the module raise this error only, if I automate the run and works like a charm, if I trigger it manually?
i would suggest, that you reattach the image and upload the sourcecode of the modifier
Thanks @moreamazingnick for your answer, but I do not understand it.
What do you mean with “image”?
And what do you mean with “upload the sourcecode”?
Cheers, Mordecaine
you uploaded an image of “I get the following message:”
but there is no image viewable in your post.
“I’ve written an own icingaweb2 director property modifier.” → please share that otherwise it is not possible to help you.
Ah ok. I understand.
So that’s funny, in my post the picture is displayed after “I get the following message”.
So I’ve created a new picture and uploaded the source Code
can you upload the following ouput:
ls -la /usr/share/icingaweb2/modules
As you wished (directorextension is the name of my module):
total 20
drwxr-xr-x. 20 root root 4096 Dec 29 13:28 .
drwxr-xr-x. 7 root root 80 Nov 18 13:06 ..
drwxr-xr-x. 10 root root 4096 Nov 22 15:25 businessprocess
drwxr-xr-x. 4 root root 152 Nov 5 11:49 datagerry
drwxr-xr-x. 11 root root 4096 Nov 5 11:47 director
drwxr-xr-x. 4 root root 108 Feb 14 09:34 directorextension
drwxr-xr-x. 6 root root 124 Nov 19 06:49 doc
drwxr-xr-x. 2 root root 31 Jan 4 14:30 global-dashboards
drwxr-xr-x. 10 root root 4096 Apr 27 2021 grafana
drwxr-xr-x. 6 root root 232 Nov 22 14:33 incubator
drwxr-xr-x. 6 root root 205 Apr 26 2021 ipl
drwxr-xr-x. 8 root root 217 Aug 3 2021 jira
drwxr-xr-x. 4 root root 59 Nov 19 06:49 migrate
drwxr-xr-x. 7 root root 136 Nov 19 06:49 monitoring
drwxr-xr-x. 6 root root 143 Oct 12 07:36 netboximport
drwxr-xr-x. 5 root root 169 Apr 26 2021 reactbundle
drwxr-xr-x. 5 root root 71 Nov 19 06:49 setup
drwxr-xr-x. 5 root root 70 Nov 19 06:49 translation
drwxr-xr-x. 10 root root 4096 Nov 29 09:44 vspheredb
Mordecaine:
directorextension
I forked your project and changes some minor details:
[https://github.com/moreamazingnick/ic2-director-modifier ]
@moreamazingnick thanks a lot. That worked really nice.
If someone has the same issues then me; you can see the changes in my pull request:
Mordecaine:main ← moreamazingnick:main
opened 10:35AM - 14 Feb 22 UTC
moreamazingnick was so nice to fix my errors.
don’t forge to
/usr/share/icingaweb2/modules/directorextension# chmod 644 run.php
it fails after unpacking:
root@my:/usr/share/icingaweb2/modules/directorextension# ls -la
total 40
drwxr-xr-x 3 root root 4096 Feb 14 10:35 .
drwxr-xr-x 24 root root 4096 Mar 25 10:11 ..
drwxr-xr-x 3 root root 4096 Feb 14 10:35 library
-rw-r--r-- 1 root root 18046 Feb 14 10:35 LICENSE
-rw-r--r-- 1 root root 198 Feb 14 10:35 module.info
-rw-r--r-- 1 root root 260 Feb 14 10:35 run.php
root@my:/usr/share/icingaweb2/modules/directorextension# chmod 644 run.php
total 40
and it magically works which makes no sense
