Icingaweb2 - AutoRefresh
Dear guys,
is there a chance to put the AutoRefresh-Time for Icingaweb2 up?
Cause everytime, when i want to do a filter, the dropdown menu is closing when y need more then 20 seconds.
Hopefully somebody has an idea.
Sincerly
Felix
Hello Felix,
you can disable refresh in your user profile :slight_smile:
Regards,
Carsten
Hey Carsten,
thanks for the fast answer. I already knew that this is possible. But my company wishes that the auto-refresh just get set on 1 Minute…
Do y have another idea?
sincerely
Felix
hi Felix,
i would edit the javascript files. but maybe @nilmerg has a better solution.
Regards,
Carsten
hi,
then i will wait for @nilmerg answer.
Would be quite nice, if this would be in the setting of Icinga2, that can decide yourself, how often the site is refreshing.
Felix
the autorefresh is currently not configurable. Though, we’re on it (see #2819) and it may be part of the next major release (2.9).
Thanks for the fast answer!
Then we will wait!
