Hi
I’ve a problem with icingaweb.
I’ve added many hosts and services and all works fine (checks are made automatically). But when I try to clik on “check now” on a host, i’ve the error:
#0 [internal function]: Icinga\Application\ApplicationBootstrap->Icinga\Application\{closure}(Integer, String, String, Integer, Array)
#1 /usr/share/php/Icinga/Exception/IcingaException.php(28): vsprintf(String, Array)
#2 /usr/share/icingaweb2/modules/monitoring/library/Monitoring/Command/Transport/CommandTransport.php(137): Icinga\Exception\IcingaException->__construct(String)
#3 /usr/share/icingaweb2/modules/monitoring/application/forms/Command/Object/CheckNowCommandForm.php(76): Icinga\Module\Monitoring\Command\Transport\CommandTransport->send(Object(Icinga\Module\Monitoring\Command\Object\ScheduleHostCheckCommand))
#4 /usr/share/php/Icinga/Web/Form.php(1171): Icinga\Module\Monitoring\Forms\Command\Object\CheckNowCommandForm->onSuccess()
#5 /usr/share/icingaweb2/modules/monitoring/library/Monitoring/Web/Controller/MonitoredObjectController.php(282): Icinga\Web\Form->handleRequest()
#6 /usr/share/icingaweb2/modules/monitoring/library/Monitoring/Web/Controller/MonitoredObjectController.php(60): Icinga\Module\Monitoring\Web\Controller\MonitoredObjectController->setupQuickActionForms()
#7 /usr/share/icingaweb2/modules/monitoring/application/controllers/HostController.php(63): Icinga\Module\Monitoring\Web\Controller\MonitoredObjectController->showAction()
#8 /usr/share/icingaweb2/library/vendor/Zend/Controller/Action.php(507): Icinga\Module\Monitoring\Controllers\HostController->showAction()
#9 /usr/share/php/Icinga/Web/Controller/Dispatcher.php(76): Zend_Controller_Action->dispatch(String)
#10 /usr/share/icingaweb2/library/vendor/Zend/Controller/Front.php(937): Icinga\Web\Controller\Dispatcher->dispatch(Object(Icinga\Web\Request), Object(Icinga\Web\Response))
#11 /usr/share/php/Icinga/Application/Web.php(300): Zend_Controller_Front->dispatch(Object(Icinga\Web\Request), Object(Icinga\Web\Response))
#12 /usr/share/php/Icinga/Application/webrouter.php(99): Icinga\Application\Web->dispatch()
#13 /usr/share/icingaweb2/public/index.php(4): require_once(String)
#14 {main}
When I look on my user.log:
Icinga\Module\Monitoring\Exception\CommandTransportException in /usr/share/icingaweb2/modules/monitoring/library/Monitoring/Command/Transport/ApiCommandTransport.php:217 with message: Got invalid JSON response from the Icinga 2 API: Syntax error: ''
ErrorException in /usr/share/php/Icinga/Exception/IcingaException.php:28 with message: vsprintf(): Too few arguments #0 [internal function]: Icinga\Application\ApplicationBootstrap->Icinga\Application\{closure}(Integer, String, String, Integer, }
I’m not able to find where it break…
It worked some days ago and I’ ve changed nothing…
My icinga version:
icinga2:
Installed: 2.11.2-1.buster
Candidate: 2.11.2-1.buster
icingaweb2:
Installed: 2.7.3-1.buster
Candidate: 2.7.3-1.buster
Sorry for long thread but I wanted to add many informations to debug.
Alex
